10-29-2008 02:28 PM - edited 03-06-2019 02:12 AM
We have a site that has a router and frame connection. There is a Cisco vpn 3002 client with a dsl connection.
In case the frame goes down, we want to forward traffic through that 3002, but want the frame to be the primary connection if it comes back up.
A.) Do I need to do a routing protocol like RIP (it doesn't support any)
B.) Will static routes on the router be sufficient like:
ip route 0.0.0.0 0.0.0.0 10.50.1.1
ip route 0.0.0.0 0.0.0.0 10.50.1.2 20
If the static routes will work, will the router always try to send traffic out of the first and then the next? In other words, if the frame comes back up will the traffic automatically go out of that?
Thanks!
John
Solved! Go to Solution.
10-29-2008 03:01 PM
As long as the 2 static routes are comparable, as they are now, then yes, the primary will be used when the next hop (10.50.1.1) comes back online.
Victor
10-29-2008 04:39 PM
John
Just to add to Victor's post. Generally a floating static such as
you would tend to set the AD to 250 or thereabouts ie.
ip route 0.0.0.0 0.0.0.0 10.50.1.2 250
this is just to ensure that any dynamic routing protocol traffic would be used before this kicks in which is generally what you want. Not a bad habit to get into.
Jon
10-29-2008 03:01 PM
Victor
10-29-2008 04:39 PM
John
Jon
