08-14-2013 08:48 AM - edited 03-07-2019 02:55 PM
I have a cisco 3750G PoE switch. I am trying to connect the switch to cisco 881 router (it is the provider router). I am connecting it on the lan interface (switch module), but the problem that I am facing right now is that the port on the switch 3750 shows as notconnect. I tried the same cable by connecting it to other device and it worked fine so I know that the cable is not an issue. I am stumped with this thing and any help on this would be really appreciated.
Config on the switch:
interface GigabitEthernet1/0/24
description Cable Modem
switchport access vlan 170
switchport mode access
speed 10
priority-queue out
mls qos trust dscp
no cdp enable
Esd0086#show int g1/0/24
GigabitEthernet1/0/24 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0026.0a4e.9f98 (bia 0026.0a4e.9f98)
Description: Alliant Cable Modem (4848)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 252/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Auto-duplex, 10Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 02:14:19, output 02:14:21, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7 packets input, 2185 bytes, 0 no buffer
Received 6 broadcasts (0 multicast)
2 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 6 multicast, 0 pause input
1 packets output, 64 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
interface vlan 170
Vlan170 24.22.54.33 YES NVRAM up down
Esd0086#show vlan b
VLAN Name Status Ports
1 default active Gi1/0/2, Gi1/0/3, Gi1/0/4
Gi1/0/5, Gi1/0/6, Gi1/0/7
Gi1/0/8, Gi1/0/9, Gi1/0/10
Gi1/0/11, Gi1/0/12, Gi1/0/13
Gi1/0/14, Gi1/0/15, Gi1/0/16
Gi1/0/17, Gi1/0/18, Gi1/0/19
Gi1/0/20, Gi1/0/21, Gi1/0/25
Gi1/0/26, Gi1/0/27, Gi1/0/28
169 vl169 active Gi1/0/1
170 vl170 active Gi1/0/22, Gi1/0/23, Gi1/0/24
999 vl999 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
08-14-2013 08:53 AM
What is the speed set to on the router's switchport? If it's hard coded to anything other than 10, the connection won't come up. Can you post the config?
HTH,
John
*** Please rate all useful posts ***
08-14-2013 08:56 AM
Forgot to mention that on the cisco 881, we have one interface on the switch module that is connected to the switch and is up and running with the speed of 10; so that is the reason I did configure speed 10 on it. I even changed the config to speed auto; but it did not help.
08-14-2013 08:57 AM
Post the config from the router please...
HTH,
John
08-14-2013 08:58 AM
it is a service provider router and do not have access to it. That is the problem.
08-14-2013 09:00 AM
Contact the service provider and see if they can help you...the switchport itself is showing down/down which technically means it's a physical problem. Since you tested the cable with another device and it came up, did you also test this device on a different port with the same cable? Try without a vlan attached to the port and see if that makes a difference....
HTH,
John
