09-23-2008 11:44 AM - edited 03-06-2019 01:33 AM
My interface has IP 172.16.1.62 and I ping a device on the same subnet with IP 172.16.1.1 and I get with debug on the response Stop process pak for forus packet. Any idea what is happening?
09-23-2008 11:58 AM
Hello Carlos,
it could be normal behaviuor it should simply say that the return packet is process switched = sent to main cpu.
I remember another thread where the same sentence in the debug ip packet was shown in the process of translating a DHCP request for the ip helper-address command.
So if the ping is successful (you are getting responses) everything should be fine
Hope to help
Giuseppe
09-23-2008 12:43 PM
Hello Giuseppe,
Yes, I am getting responses. The real problem is that my switch has another interface, e.g., 158.97.80.62 and I try to ping 172.16.1.1 from my MacBook 158.97.80.30 and I never get responses...
09-23-2008 01:00 PM
Hello Carlos,
try to use debug ip icmp on the switch and from the MAC try to ping
before doing that :
verify that 158.97.80.62 and 158.97.80.30 are in the same IP subnet;
that 158.97.80.62 is the GW for the 158.97.80.30
if you have ACL on L3 interfaces or you are doing NAT this can change the ping results:
what if from switch you do an extended ping to 158.97.80.30 with source 172.16.1.1 ?
Hope to help
Giuseppe
08-31-2018 06:10 AM
Lets we know where you are getting the log, in virtual setup or physical setup?
