Storm Control and why are the process so high with only 2 pc connected to the switch stack.
Dear Tech Support
I have a cisco catalyhst 3750x.
I liked to implemtnet the storm control mechnism to avoid downtime. but how do it know when i user is copy a large file over the network , or the users is being victim of an atack FROM his computer to the servers or workstations locally.
I have setup a storm control mechanism with the following parameters show below, but the results is:
- The workstation on port 10 copy 1.3gb for testing. Every 10 sec on average, exceed the upper limit to 680pps, then the port goes into blocking stage , then when it drops to 280pps or so, the port goes into forwading again.( becuase it went below 580pps).
Questions:
  1. What do i need to do to only trigger the trap wihout blocking the state on that port ?
  2. And whty does my procesor on the master switch goes to 69% when only 2 pcs are connected.
see the config - thank you,
UHA-AMP-R-SwStack01#show storm-control
Interface Filter State Upper Lower Current
Gi1/0/10 Forwarding 600 pps 580 pps 0 pps
! stackwise function
switch 1 provision ws-c3750x-48p
switch 2 provision ws-c3750x-48p
switch 3 provision ws-c3750x-24p
.... Truncated restt of the config
interface GigabitEthernet1/0/10
switchport access vlan 21
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
storm-control broadcast level pps 600 580
storm-control multicast level pps 600 580
storm-control unicast level pps 600 580
storm-control action trap
spanning-tree portfast
spanning-tree bpduguard enable
end
1 REPLY
Re: Storm Control and why are the process so high with only 2 pc
Hello
I personally found setting storm control on bps/pps values a bit time consuming - It does give you a more specifc control over the interface traffic but I have found using BW utilization a better option.
What do i need to do to only trigger the trap wihout blocking the state on that port ? - Dont think you can as this is the default feature of storm control
Looking  at your config you have enabled SC for all traffic and the action is to  send a trap message, this will still prohibit whatever traffic rises  above the specifed thresholds but it shouldnt errordisable the port as  like the SC shutdown action would do, then i suppose you could specify  errdisable recovery to attempt auto recover the port at a specific time  interval anyway
And why does my procesor on the master switch goes to 69% when only 2 pcs are connected.
Not sure on this one -How are  they connected?
Does this only occur when SC is enabled on the ports?
Is it specific to these two pcs?
Have you check/changed the cabling?
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Please don't forget to rate any posts that have been helpful. Thanks.
178
