Webcast-Catalyst9k
storm-control recommendation
Dear all,
I'm playing with storm-control for a better network stability.
I use this configuration it it seem to work fine, because I get no traps .. BUT today i had a attack to one router and the strom-control didn't inform me.
So I'm thining of imporving that. Maybe is it PC Problem or line or Port, after resetting the port it was gone..
Aanyway any experience from you would be nice to hear.
Is maybe a %level better than pps?
storm-control broadcast level pps 100
storm-control multicast level 50.00
storm-control action trap
What are u guys using in the field? We have a /24 per Switch and no special broadcast appl.
regards,
Sebastian
1 REPLY
We allow 5% per 100mb port, and 10% per 1gb port. The uplinks generally get 25%. I've asked this question in the past, and it's one of those things that you'll probably want to play with until you get it aligned correctly with your network and what the 'norm' should be.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
307
