STP and potential loops - 2 switches
Hi guys, I have 2 switches, both WS2960. I have a single trunk between them and STP is only running on the native VLAN.
By only having a single trunk, am I still creating a possibility of looping back over the same trunk? Should I create a second trunk to avoid loops over a simple two switch network?
Dean
1 ACCEPTED SOLUTION
Silver
Re: STP and potential loops - 2 switches
Hi Dean
With a single trunk link between two switches there is no loop issue. This is a point to point link. So unless someone connects a second cable between the switches, there you will not have looping issues.
However if and when you add a second link between the switches, this is when you have created a loop and require STP.
AFAIK STP is active for all VLAN's automatically by default on Cisco switches.
Best Regards,
Michael
1 REPLY
Silver
Hi Dean
Best Regards,
Michael
262
