Community Member
STP Between Cisco and Linksys
Hi All
I want to enable STP between Cisco 3560 and Linksys SRW248 G4 switches, my Linksys switch is connected to the 3560 on separate VLAN, i want to connect another link with same VLAN connecting both the switch. Here by to prevent the loop i want to enable the STP.
I have few query on this,
1) 3560 supports only pvst and repid pvst, this is it possible to enable the STP on this switches?
2) if yes, i didnt found PVST configuration on linksys switch as PVST is cisco proprietary.
3) if no, is there any other option to connect two switches in this environment with redundant links by preventing the loop?
please any body have idea on this let me know.
- Dhaval Tandel
Re: STP Between Cisco and Linksys
Hi Dhaval,
3560 runs PVST+ which is compatible with STP on switches other than Cisco. So you need to worry about the 2 links as one link will go in blocking state.
1) We cannot enable CST on cisco switches and they default run PVST+
2) PVST is Cisco prop. but PVST+ interoperate with non cisco switches
3) See if this link helps you
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00801d11a0.shtml#topic1
http://safari.oreilly.com/1587052733/ch05lev1sec8
Ankur
*Pls rate all helpfull post
Community Member
Hi Ankur
Thanks for the quick response,
Actually i have tried by putting both link up at same time and was constantly pinging to node at other network, and as i put the another link up i got unreachable.
any idea on this?
is it due to the calculation time it take to make one link down?
- Dhaval Tandel
Hi Dhaval,
As you said it went unreachable, can you confirm for how much time or it was not reachable forever after you made another link up?
Also at the time it was unreachable we can check on cisco switch the state of the spanning tree on those interfaces if the ports are transitioning to blocking state or not.
Ankur
Community Member
HI
Actually it is my live network i wanted to configure redudant link which interconnect my branch office to HO so i cant wait up to that time, if there is some time introduction i need to plane accordingly.
that is the reason i have just keep the secondary link in to the 3560 for less than 30 Sec.
- Dhaval Tandel
303
