STP confusion :(
Hi all ,
We have configured this switch as root for vlan a and vlan b(example) . But in one vlan i am able to see this switch is the root . whereas other vlan is not showing. But both BID and RID mac address denoting the same switch ...
Logs as below .
Switch# show spanning-tree vlan a
VLAN0258
  Spanning tree enabled protocol rstp
  Root ID    Priority    4354
             Address     64a0.e743.82c1
             This bridge is the root
             Hello Time  2  sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    4354   (priority 4096 sys-id-ext 258)
Interface        Role Sts Cost      Prio.Nbr Type
interface             Desg FWD 1         128.4115 P2p
switch# show spanning-tree vlan y
VLAN0259
             Cost        14
             Port        4115
  Bridge ID  Priority    4355   (priority 4096 sys-id-ext 259)
interface     Root FWD 1         128.4115 P2p
Any idea on this....
STP confusion :(
I believe the root priority in Vlan0259 should be 4355 whereas it is 4354.
Try configuring the Root priority in Vlan0259 again.
And if it is in PT try rebboting the switch.
Please don't mind if my suggestion doen't help. Even i'm still learning.
Chandu
Regards, Chandu
STP confusion :(
Somewhere in your infrastructure there is another switch advertising better BPDUs for vlan259. Track that switch down and figure out what it's STP configuration is. Could be it's priority is 0 or it's priority is also 4096 with a lower MAC
Re: STP confusion :(
vijay,
What you can do, is do a 'show span vlan 259', and then do a 'show cdp neighbor' and you should be able to track the switch down.
Just follow the root port.
141
