11-22-2011 01:53 AM - edited 03-07-2019 03:31 AM
Dear all,
Any one know what is the STP cost of 20G link and 40G link in RSTP. As I know, If 10G link, the RSTP cost is 2000
Thx!
11-22-2011 02:27 AM
STP cost for 10G is not 2000 it is 2 only
Anything above 10G, cost is 1.
HTH,
Smitesh
11-22-2011 02:35 AM
Dear Smitesh,
I want to ask the RSTP cost (802.1w), not PVST cost (802.1D). If pvst cost, your answer is correct.
Thanks!.
11-22-2011 02:52 AM
Port cost doesn't get changed whether it is PVST or RSTP or MST.
Difference is on modes and spanning tree instances.
Smitesh
11-22-2011 07:31 AM
Dear Smitesh,
Maybe I have some confuse on STP. I would like to ask what is the MST cost of 20G and 40G link
Thanks!
11-22-2011 09:24 AM
New revised cost chart for any of the STP flavour (STP, PVST+, RSTP, MST) is as below:
Speed of Ethernet Revised IEEE Cost
10 Mbps 100
100 Mbps 19
1 Gbps 4
10 Gbps 2
Anything above 10G 1
Smitesh
