STP problem on vlan 1 in a heterogeneous network.
achica
we have an heterogeneous network with Cisco devices (6509-E, 3750G and 3560) and Alcatel 6850 devices. We have to enable a PTP Wifi line as a backup for the fiber line between two buildings. For this purpose, we have connected a wifi device to GigabitEthernet 0/47 of SWIHGJ1 and configured it as:
SWIHGJ1#show running-config interface GigabitEthernet 0/47
Building configuration...
Current configuration : 298 bytes
interface GigabitEthernet0/47
description Antena WiMax HG
power inline never
switchport trunk allowed vlan 1,2,4-6,9-15,24,51,1002-1005
switchport mode trunk
switchport nonegotiate
shutdown
spanning-tree port-priority 176
spanning-tree cost 100
end
I enclose you a topology picture to ilustrate this.
When we enable this interface, all VLANs are blocked except VLAN 1 that produces a loop into the network.
SWIHGJ1#
SWIHGJ1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SWIHGJ1(config)#int gi0/47
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#do sh run int gi 0/47
power inline never
shutdown
end
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#do sh span blocked
Name                 Blocked Interfaces List
Number of blocked ports (segments) in the system : 0
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#no shut
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
3877112: Aug 13 22:24:01.751 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/47, changed state to down
3877113: Aug 13 22:24:02.313 UTC: set portid: VLAN0001 Gi0/47: new port id B02F
3877114: Aug 13 22:24:02.313 UTC: STP SW: Gi0/47 new blocking req for 1 vlans
3877115: Aug 13 22:24:02.313 UTC: STP: VLAN0001 Gi0/47 -> listening
3877116: Aug 13 22:24:02.313 UTC: set portid: VLAN0002 Gi0/47: new port id B02F
3877117: Aug 13 22:24:02.313 UTC: STP: VLAN0002 Gi0/47 -> listening
3877118: Aug 13 22:24:02.313 UTC: set portid: VLAN0004 Gi0/47: new port id B02F
3877119: Aug 13 22:24:02.313 UTC: STP: VLAN0004 Gi0/47 -> listening
3877120: Aug 13 22:24:02.313 UTC: set portid: VLAN0005 Gi0/47: new port id B02F
3877121: Aug 13 22:24:02.313 UTC: STP: VLAN0005 Gi0/47 -> listening
3877122: Aug 13 22:24:02.313 UTC: set portid: VLAN0006 Gi0/47: new port id B02F
3877123: Aug 13 22:24:02.313 UTC: STP: VLAN0006 Gi0/47 -> listening
3877124: Aug 13 22:24:02.313 UTC: set portid: VLAN0009 Gi0/47: new port id B02F
3877125: Aug 13 22:24:02.313 UTC: STP: VLAN0009 Gi0/47 -> listening
3877126: Aug 13 22:24:02.321 UTC: set portid: VLAN0010 Gi0/47: new port id B02F
3877127: Aug 13 22:24:02.321 UTC: STP: VLAN0010 Gi0/47 -> listening
3877128: Aug 13 22:24:02.321 UTC: set portid: VLAN0011 Gi0/47: new port id B02F
3877129: Aug 13 22:24:02.321 UTC: STP: VLAN0011 Gi0/47 -> listening
3877130: Aug 13 22:24:02.321 UTC: set portid: VLAN0012 Gi0/47: new port id B02F
3877131: Aug 13 22:24:02.321 UTC: STP: VLAN0012 Gi0/47 -> listening
3877132: Aug 13 22:24:02.321 UTC: set portid: VLAN0013 Gi0/47: new port id B02F
3877133: Aug 13 22:24:02.321 UTC: STP: VLAN0013 Gi0/47 -> listening
3877134: Aug 13 22:24:02.321 UTC: set portid: VLAN0014 Gi0/47: new port id B02F
3877135: Aug 13 22:24:02.321 UTC: STP: VLAN0014 Gi0/47 -> listening
3877136: Aug 13 22:24:02.321 UTC: set portid: VLAN0015 Gi0/47: new port id B02F
3877137: Aug 13 22:24:02.321 UTC: STP: VLAN0015 Gi0/47 -> listening
3877138: Aug 13 22:24:02.321 UTC: set portid: VLAN0024 Gi0/47: new port id B02F
3877139: Aug 13 22:24:02.321 UTC: STP: VLAN0024 Gi0/47 -> listening
3877140: Aug 13 22:24:02.321 UTC: set portid: VLAN0051 Gi0/47: new port id B02F
3877141: Aug 13 22:24:02.321 UTC: STP: VLAN0051 Gi0/47 -> listening
3877142: Aug 13 22:24:04.217 UTC: STP SW: Gi0/47 new blocking req for 1 vlans
3877143: Aug 13 22:24:04.217 UTC: STP: VLAN0011 Gi0/47 -> blocking
3877144: Aug 13 22:24:04.217 UTC: STP SW: Gi0/47 new blocking req for 1 vlans
3877145: Aug 13 22:24:04.217 UTC: STP: VLAN0012 Gi0/47 -> blocking
3877146: Aug 13 22:24:04.217 UTC: STP SW: Gi0/47 new blocking req for 1 vlans
3877147: Aug 13 22:24:04.217 UTC: STP: VLAN0013 Gi0/47 -> blocking
3877148: Aug 13 22:24:04.217 UTC: STP: VLAN0014 Gi0/47 -> blocking
3877149: Aug 13 22:24:04.225 UTC: STP: VLAN0015 Gi0/47 -> blocking
3877150: Aug 13 22:24:04.225 UTC: STP: VLAN0024 Gi0/47 -> blocking
3877151: Aug 13 22:24:04.225 UTC: STP: VLAN0051 Gi0/47 -> blocking
3877152: Aug 13 22:24:04.284 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/47, changed state to up
3877153: Aug 13 22:24:05.014 UTC: STP SW: Gi0/47 new blocking req for 1 vlans
3877154: Aug 13 22:24:05.014 UTC: STP: VLAN0002 Gi0/47 -> blocking
3877155: Aug 13 22:24:05.014 UTC: STP: VLAN0004 Gi0/47 -> blocking
3877156: Aug 13 22:24:05.014 UTC: STP: VLAN0005 Gi0/47 -> blocking
3877157: Aug 13 22:24:05.014 UTC: STP: VLAN0006 Gi0/47 -> blocking
3877158: Aug 13 22:24:05.014 UTC: STP: VLAN0009 Gi0/47 -> blocking
3877159: Aug 13 22:24:05.014 UTC: STP: VLAN0010 Gi0/47 -> blocking
3877160: Aug 13 22:24:05.291 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/47, changed state to up
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#do sh spanning-tree blocked
VLAN0002             Gi0/47
VLAN0004             Gi0/47
VLAN0005             Gi0/47
VLAN0006             Gi0/47
VLAN0009             Gi0/47
VLAN0010             Gi0/47
VLAN0011             Gi0/47
VLAN0012             Gi0/47
VLAN0013             Gi0/47
VLAN0014             Gi0/47
VLAN0015             Gi0/47
VLAN0024             Gi0/47
VLAN0051             Gi0/47
Number of blocked ports (segments) in the system : 13
SWIHGJ1(config-if)#
3877161: Aug 13 22:24:17.320 UTC: STP SW: Gi0/47 new learning req for 1 vlans
3877162: Aug 13 22:24:17.320 UTC: STP: VLAN0001 Gi0/47 -> learning
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
3877163: Aug 13 22:24:25.977 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a25.8f00 in vlan 1 is flapping between port Gi0/47 and port Po1
SWIHGJ1(config-if)#
VLAN0002             Gi0/47
VLAN0004             Gi0/47
VLAN0005             Gi0/47
VLAN0006             Gi0/47
VLAN0009             Gi0/47
VLAN0010             Gi0/47
VLAN0011             Gi0/47
VLAN0012             Gi0/47
VLAN0013             Gi0/47
VLAN0014             Gi0/47
VLAN0015             Gi0/47
VLAN0024             Gi0/47
VLAN0051             Gi0/47
SWIHGJ1(config-if)#
3877164: Aug 13 22:24:32.327 UTC: STP SW: Gi0/47 new forwarding req for 1 vlans
3877165: Aug 13 22:24:32.327 UTC: STP: VLAN0001 sent Topology Change Notice on Po1
3877166: Aug 13 22:24:32.327 UTC: STP: VLAN0001 Gi0/47 -> forwarding
3877167: Aug 13 22:24:32.713 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a24.6140 in vlan 1 is flapping between port Gi0/47 and port Po1
3877168: Aug 13 22:24:33.904 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a25.8f00 in vlan 1 is flapping between port Po1 and port Gi0/47
SWIHGJ1(config-if)#
3877178: Aug 13 22:24:45.170 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000f.2066.a100 in vlan 1 is flapping between port Po1 and port Gi0/47
VLAN0002             Gi0/47
VLAN0004             Gi0/47
VLAN0005             Gi0/47
VLAN0006             Gi0/47
VLAN0009             Gi0/47
VLAN0010             Gi0/47
VLAN0011             Gi0/47
VLAN0012             Gi0/47
VLAN0013             Gi0/47
VLAN0014             Gi0/47
VLAN0015             Gi0/47
VLAN0024             Gi0/47
VLAN0051             Gi0/47
3877179: Aug 13 22:24:46.236 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a25.8f00 in vlan 1 is flapping between port Po1 and port Gi0/47
3877180: Aug 13 22:24:46.236 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000d.9df5.ments) in the system : 13
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#
SWIHGJ1(config-if)#7c00 in vlan 1 is flapping between port Po1 and port Gi0/47
3877181: Aug 13 22:24:46.286 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 000f.2066.a100 in vlan 1 is flapping between port Gi0/47 and port Po1
3877182: Aug 13 22:24:53.651 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a24.6140 in vlan 1 is flapping between port Gi0/47 and port Po1
3877183: Aug 13 22:25:01.520 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a25.8f00 in vlan 1 is flapping between port Gi0/47 and port Po1
3877184: Aug 13 22:25:07.493 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 00d0.95e3.cd44 in vlan 1 is flapping between port Gi0/47 and port Po1
3877185: Aug 13 22:25:08.147 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 00e0.b1a2.5ade in vlan 1 is flapping between port Gi0/47 and port Po1
3877186: Aug 13 22:25:11.746 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a24.6140 in vlan 1 is flapping between port Gi0/47 and port Po1
3877187: Aug 13 22:25:12.970 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 00e0.b19a.4008 in vlan 1 is flapping between port Gi0/47 and port Po1
SWIHGJ1(config-if)#
Could you please, help us with this issue?.
Best regards.
Antonio de la Chica.
acampbell
Antonio,
You only seem to see the STP looping problem with VLAN 1.
With the interface shut try and find out where the root bridge for VLAN 1 resides and compare to other good VLANs like 2 etc.
You could also try changing the stp prt cost to an extreme number like "spanning-tree cost 5000"
just to test.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hello Alex,
thank you very much for your quick response.
You're right my spanning-tree loop is only at vlan 1, as you can check into the following "show spanning-tree" command output during a loop:
3876992: Aug 13 21:33:22.323 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 001c.c58a.9020 in vlan 1 is flapping between port Gi0/47 and port Po1
3876993: Aug 13 21:33:22.323 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 00e0.b1a2.5ade in vlan 1 is flapping between port Gi0/47 and port Po1
3876994: Aug 13 21:33:23.740 UTC: %SW_MATM-4-MACFLAP_NOTIF: Host 0026.0a24.6140 in vlan 1 is flapping between port Po1 and port Gi0/47
SWIHGJ1#  sh span
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    1
             Address     0026.0a24.6140
             Cost        8
             Port        56 (Port-channel1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     0027.0c6c.9e80
             Aging Time 15
Interface        Role Sts Cost      Prio.Nbr Type
Gi0/47           Desg FWD 100       176.47   P2p
Gi0/48           Desg FWD 4         128.48   P2p
Po1              Root FWD 4         128.56   P2p
VLAN0002
  Root ID    Priority    2
             Cost        8
  Bridge ID  Priority    32770  (priority 32768 sys-id-ext 2)
             Aging Time 15
Gi0/1            Desg FWD 4         128.1    Edge P2p
Gi0/2            Desg FWD 4         128.2    Edge P2p
Gi0/3            Desg FWD 4         128.3    Edge P2p
Gi0/4            Desg FWD 4         128.4    Edge P2p
Gi0/5            Desg FWD 4         128.5    Edge P2p
Gi0/7            Desg FWD 19        128.7    Edge P2p
Gi0/8            Desg FWD 4         128.8    Edge P2p
Gi0/9            Desg FWD 100       128.9    Edge P2p
Gi0/10           Desg FWD 4         128.10   Edge P2p
Gi0/11           Desg FWD 4         128.11   Edge P2p
Gi0/12           Desg FWD 100       128.12   Edge P2p
Gi0/13           Desg FWD 19        128.13   Edge Shr
Gi0/14           Desg FWD 19        128.14   Edge P2p
Gi0/20           Desg FWD 4         128.20   Edge P2p
Gi0/24           Desg FWD 19        128.24   Edge P2p
Gi0/25           Desg FWD 19        128.25   Edge P2p
Gi0/27           Desg FWD 19        128.27   Edge P2p
Gi0/28           Desg FWD 19        128.28   Edge P2p
Gi0/29           Desg FWD 4         128.29   Edge P2p
Gi0/30           Desg FWD 4         128.30   Edge P2p
Gi0/31           Desg FWD 100       128.31   Edge P2p
Gi0/32           Desg FWD 4         128.32   Edge P2p
Gi0/33           Desg FWD 4         128.33   Edge P2p
Gi0/34           Desg FWD 4         128.34   Edge P2p
Gi0/35           Desg FWD 100       128.35   Edge P2p
Gi0/37           Desg FWD 19        128.37   Edge Shr
Gi0/47           Altn BLK 100       176.47   P2p
VLAN0004
  Root ID    Priority    4
             Cost        8
  Bridge ID  Priority    32772  (priority 32768 sys-id-ext 4)
             Aging Time 15
The rest of VLANs has the same result and it is the same topology with this interface shutted down.
Finally, I'll try to increment this interface cost to 5000 as you suggest and I'll tell you the result.
Thank you very much for your help.
Antonio.
