05-24-2008 03:04 PM - edited 03-05-2019 11:12 PM
Hi Friends
I have 3 switch connected in triangle fashion, A-B-C-A and i have force switch A to Root bridge by command "root primary" Now i am adding one more switch into network setup, i.e Switch D, i am modifying switch prioriy manualy 2 , in that case all who wil be root bride.
All the switch are in Vlan100.
Please tell me i am stuck up in the middle of reading ..
-M
05-24-2008 11:14 PM
its going to depend whats the priority of the current root bridge.i think whne u configure it for the root primary its going to set a default priority of 8192..not sure.So if u r going to introduce a new switch a priority lower than the current root,this switch is going to assume the role of the root switch.
Mahmood
05-25-2008 03:43 AM
I agree.
I agree the root primary is a macro that expands in the necessary commands but it is executed ony one time.
Whatever priority value has been used on switch A if the new switch D has a lower priority it will become the new root bridge.
hope to help
Giuseppe
05-26-2008 09:32 AM
That means if switch is configure with Root primary command will make no difference if i will introduce one more switch with lower priority...
-Minu
05-26-2008 10:27 AM
Yes,if u introduce a new switch with lower priority its gonna assume the role of the root bridge.
Mahmood
