02-01-2014 07:12 AM - edited 03-07-2019 05:56 PM
Hi All,
A UTP cable have 8 wires. As straight through cable have only 4 functional wires as 1 2 3 6 . Can i use remaining 4 wires with straight through wire config to connect another device? i.e: one end of utp cable is connected to router ethernet interface and other end with 2 ip phones or 2 switches using one straight through wire ?
Is it possible to do so? I think no.but want you guys expert opinion.
Thank you
Solved! Go to Solution.
02-02-2014 06:22 AM
Take a look at this; it should help:
http://www.instructables.com/id/How-to-make-your-own-Ethernet-%22splitter%22/
HTH,
John
*** Please rate all useful posts ***
02-01-2014 07:20 AM
You'd have to make sure your pinouts were correct and that you're not using poe because I believe it uses another pair of unused wire. Also, you'll never get Gb speeds out of it because you need all 4 pair for gb ethernet.
That being said, your standard straight though is:
ow o gw b bw g brW br
On one connection, you could use:
1 2 3 6
ow o gw g
The other connection would be
4 5 7 8
b bw brW br
I must say that you will more than like experience crosstalk, corrupted data, and generally any other anomalies that would occur with a bad cable. Although, it may work flawlessly as I've never done this.
HTH,
John
02-01-2014 05:36 PM
If you do it you can only have a 100 meg connection . Gigabit uses all 8 wires.
02-02-2014 05:30 AM
Also if you are attaching ip phones and planning on injecting power from a Poe switch, that will not work with split cabling.
02-02-2014 05:57 AM
Hmmmm ok, so how can do it ? Can you please explain.
For one connector i will use 1 2 3 and 6th wire, and for other connector 4 5 7 and 8th?
If so then on the other end of cable all eight wires are together in a RJ45 connector which is connected to router's ethernet interface.
What do you think that it works?
I did in the same way but it wasn't working.May be i did something wrong to make cable.
But if it is possible then please expalin how?
Thank you
02-02-2014 06:22 AM
HTH,
John
