Community Member
Strange dropped packet problem
Hi all,
I've come across a strange problem today with dropped packets through an 871. Both Vlan1 and F4 show a large number of input drops, but no other errors. CEF is enabled on both interfaces, and I have also tried with fast switching and increasing the input buffer to 4000, which stops the interface input drops increasing, but doesnt stop the dropped ping packet problem. Any ideas would be greatfully received!
From F4 to a host on Vlan1:
Sending 1000, 100-byte ICMP Echos to 88.21.n.n, timeout is 2 seconds:
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 001a.6ce9.7d68 (bia 001a.6ce9.7d68)
Internet address is
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Last input 00:00:00, output never, output hang never
Input queue: 0/4000/6601683/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/100 (size/max)
5 minute input rate 202000 bits/sec, 252 packets/sec
5 minute output rate 502000 bits/sec, 200 packets/sec
35406939 packets input, 3701499054 bytes, 1357 no buffer
Received 47495 broadcasts, 0 runts, 0 giants, 0 throttles
33159172 packets output, 4246981770 bytes, 0 underruns
0 output errors, 1 interface resets
interface Vlan1
ip address
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache same-interface
ip route-cache flow
ip policy route-map CLEAR_DF
hold-queue 4000 in
hold-queue 100 out
interface FastEthernet4
ip address 88.21.n.n
ip access-group 104 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1400
ip nat outside
ip inspect FW out
ip route-cache flow
ip tcp adjust-mss 1400
duplex auto
speed auto
crypto map VPN
hold-queue 4000 in
Internet address is
Broadcast address is
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is 103
Proxy ARP is disabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are never sent
ICMP unreachables are never sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is enabled
IP Flow switching is enabled
IP CEF switching is enabled
IP CEF Flow Fast switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, Flow cache, CEF, Full Flow
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is enabled, using route map CLEAR_DF
Network address translation is enabled, interface in domain inside
BGP Policy Mapping is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
Re: Strange dropped packet problem
By default, all layer 2 ports are in dynamic desirable mode, so the layer 2 port tries to form a trunk link and sends out DTP packets to the remote device. When a layer 3 interface is connected to a layer 2 switchport, it is not able to interpret these frames, which results in Input errors, WrongEncap errors, and Input queue drops.
In order to resolve this, change the mode of the switch port to static access or trunk as per your requirement.
