Strange situation with ASA interfaces
Hello, everybody!
I have a strange situation with my ASA.
It has an interface:
sz(config-if)# show int eth0/1.1
Interface Ethernet0/1.1 "LAN", is down, line protocol is down
  Hardware is i82546GB rev03, BW 100 Mbps, DLY 100 usec
        VLAN identifier 55
        Description: === LAN, vlan 55 ===
        MAC address 4403.a706.e9af, MTU 1500
        IP address 10.64.29.2, subnet mask 255.255.255.0
  Traffic Statistics for "LAN":
        0 packets input, 0 bytes
        0 packets output, 0 bytes
        0 packets dropped
It is connected to 2950 switch and led is on and it is green. I can ping eth0/1.1 from switch, but can't ping it from ASA!!! WTF???
No doubts, I've done "no shutdown'' for this interface on ASA.  But it still "Interface Ethernet0/1.1 "LAN", is down, line protocol is down"
What could be the problem? Please, help!
Many thanks in advance!!!
Purple
Have you no shut the main physical interface ?
Alain
Im confused, are you saying you can ping the 10.64.29.2 address from the switch thats connected to the ASA???
As eth0/1.1 is a subinterface of eth0/1, can you confirm the status of eth0/1 on the ASA? Is it showing up?
Can you also show us the config for subinterface?
Actually, the admin has set this IP to switch, so I had pinged the switch instead of the ASA. And Alain was right, firstly I had to make "no shut" for main physical interface. Now everything is OK.
Many thanks to you both!
139
