Strange Strange Brodcast
hello
i cleared the counter for my gig interface connected to DS.and i watch my strange brodcast:
brodcast incresed every second i issue sh interface gig0/1
92601
185392
271123
314004
335597
364242
385654
1078788
2935007
plz help to overcome
Hall of Fame Super Bronze
Re: Strange Strange Brodcast
What is DS ?
Can you post the output from show interface g0/1 ?
hello edison!
ds:its distribution:
SW#sh interfaces gigabitEthernet 0/1
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Link type is autonegotiation, media type is SX
output flow-control is off, input flow-control is off
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 03:59:45
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 7006000 bits/sec, 7053 packets/sec
5 minute ouxtput rate 0 bits/sec, 0 packets/sec
102537443 packets input, 4241617996 bytes, 0 no buffer
Received 102361096 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 102195392 multicast, 0 pause input
4618 packets output, 862882 bytes, 0 underruns
edison
have a look to the Brodcast now:
Received 118415322 broadcasts.help me to Kill This Brodcast
wow, you have a ton of input traffic with no output traffic.
Did you try telneting to the device connected on G0/1 ? What type of device is connected to G0/1 ?
It looks like you have a virus.
hello!
gig0/1 Connected to Distribution-Switch.help
Did you telnet to this switch and check the port counters to identify which switchport is the one sending the most traffic ?
do i need to check every port by sh interface fx/y
10xs
The first question coming to my mind: what is causing the broadcast traffic? Can you use a packet analyzer like Wireshark to record the packets utilizing a SPAN port?
This should help to identify the cause of the broadcast packets and thus maybe allow you to stop it at the origin.
I know some applications use broadcast to distribute data, which could explain the observed behaviour.
Regards, Martin
in the wireshake gives us Ipv6 traffic try to join Multicast group.we dont have ipv6 enabled
so shut off the ipv6 on the clients that are trying to join... Vista has ipv6 enabled by default.
Which source MAC address is seen? Track the source MAC address(es) to the switch port(s) connecting the end device(s). In some operating systems IPv6 is turned on by default (or misconfiguration by admins).
Once you know the end device you need to check the operating system settings. In MS you could simply disable the protocol for the network card in the LAN Properties Tab.
Regards, Martin
the Source is Empty
Empty? you mean all zeros as source MAC address? A standard ethernet frame has to have a source MAC and a destination MAC. Can you attach a small sample of collected packets in a zipped file?
Regards, Martin
yeh its coming from the Distribution the IP of the interface Vlan 12.12.12.3?helpppppppppppppp.what happend?
hello
here's my captured file.have a look
10xs
edison any reply here based on the above diagrams.and could i stop this Brodacst due to ICMP IPv6
Ali,
Based on the screenshot you posted, it seems you are seeing lots of MLD (Multicast Listener Discovery) packets.
You can control and block this traffic by following this URL
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/ipv6_r/ipv6_06g.htm#wp2016579
Hello Edison
i have 2 DSs 720 each.
interface Vlan 100 and interface vlan 101.plz lit the Switable config according this 2 interfaces
10xs
Hi Ali,
Since the traffic is coming from the switch and you are sure that IPv6 is disabled in the switch. Can you post the "show version" output of the switch? It could be a bug.
Regardes,
Dandy
how can i know ipv6 is disable on the Switch(6509 720)?
Hi Ali,
show ipv6 interface [interface-id]
show ipv6 route
show ipv6 static
Make sure you don't use IPv6 first.
In the global configuration mode
SW(config)# no ipv6 unicast-routing
In the interface configuration mode
SW(config-if)#no ipv6 enable
Dandy
HELLO
WHAT ABOUT THE GROUP STATE BASED ON THE SCREENSHOT TO DEFINE THE IPV6 ACCESS-LIST?
10XS
and also based on the snapshot.i didnt understand this:ff04::10 do i need to configure it or find the Destination based on my snapshot
10xs
Hello edison!
in my situation what is state for groups based in my screen shot?i have a lots of groups
10xs
hello
any extra Reply
10xs
have a look at the source mac addresses seen, which is HighTech_1d:b3:01 in the screenshot. Track the mac address in the switches to the access port (presumably "show mac-address-table") and have a look at the attached device. I would assume the source is not a switch, but a host with default IPv6 settings. Once you found the host(s), check the network card settings and disable IPv6, as you do not want it to be active. In case you do not know how to disable it, please provide more informations on the host(s) causing the issue.
In brief:
1) find access port in the switches by tracking MAC address
2) identify host connected
3) check network card settings connected to switch port
Regards, Martin
Hello
how can i track A MAC ADDRESS?
10XS
hello
I DID EVERY THING BUT THE PROBLEM(BRODCAST) STILL EXIST.HOW U HELP?
10XS
174
