Strange Trunking issue
skhirbash
I am working on configuring switches with VLANs and trunking these switches using dot1q encapsulation. I configured two ports from two switches as trunk ports properly, but when executing a sho cdp neigh or trying to ping one another, there is no link between the two. Below, I am listing the output of both ports from both switchs.
What seems to be the problem that is preventing the establishment of the trunk?
Thanks in advance,
sK
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Switchport: Enabled
Voice VLAN: none
Protected: false
7 Replies 7
Edison Ortiz
Please post the output from typing
show int trunk and show int status from both devices.
__
Edison.
NY-SW1#sho interfaces trunk
Port Mode Encapsulation Status Native vlan
Fa0/48 on 802.1q trunking 1
Gi0/1 on 802.1q trunking 1
Gi0/4 on 802.1q trunking 1
Port Vlans allowed on trunk
Fa0/48 1-4094
Gi0/1 1-4094
Gi0/4 1-4094
Port Vlans allowed and active in management domain
Fa0/48 1,20,30,40,50
Gi0/1 1,20,30,40,50
Gi0/4 1,20,30,40,50
Port Vlans in spanning tree forwarding state and not pruned
Fa0/48 1
Gi0/1 1,20,30,40,50
Gi0/4 1,20,30,40,50.
NY-SW1# sho int status
Gi0/4 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Sac-SW2#sho interfaces trunk
Gi0/3 on 802.1q trunking 1
Gi0/3 1-4094
Gi0/3 1,20,30,40,50
Gi0/3 1,20,30,40,50
Sac-SW2#sho int status
Gi0/3 connected trunk a-full a-1000 10/100/1000BaseTX SF
Well, trunking is up and forwarding the Vlans.
You mentioned you are unable to ping from switch to switch, can you post the output from typing
show vtp status, show vlan and show ip interface | ex una from both switches.
__
Edison.
Output in attched file.
Couple of comments from the output you posted:
1) VTP
Switch 1 Configuration Revision : 13
Switch 2 Configuration Revision : 0
The VTP mode on switch 1 VTP Operating Mode : Server
The VTP mode on switch 2 VTP Operating Mode : Client
Both switches have the same VTP domain name SKTECH.
Question, did you create the Vlans manually on switch 2 and then changed the VTP mode to client ? If the client switch inherited all Vlans from the server switch, the configuration revision will be the same.
Change the domain name in the client switch to something else, change it back to SKTECH and bounce the trunk interfaces with shut and no shut.
2. I ask for the show ip interface | ex una output, it should display only interfaces with IP on it. You mentioned you can't ping from switch to switch, right ? Then the switches must have IP on them. Unless you referred to pinging from workstations connected on Switch1 to workstations connected on Switch2. Which is it?
The answer to your first qustion is yes. Sac-SW2 was connected to a different VTP domain and then I connected it to NY-SW1 and trunked the porst, set the mode to client. As for your other questions, the attached file has all the output you asked for.
Thanks much!
sK
Ed.. Thganks for all help. As it turns out that the GLC-T on Sw2 was bad. Once I replaced it with a new one, everything worked as they should..
Thanks again,
sK
