Stuck at the Initial stage CISCO pix 515e
srikanth ath
Level 4
Level 4
I have a new pix 515e for Home pratice.
1. I couldnt telnet the switch after configuring. should i have to use cross cable or not to connect PC-PIX? (as new switches and routers run through straight cable). more importantly i couldnt even ping the inside ip which is telnet and ssh enabled.
2.  Recieveing the following after executing each and every command on global mode.
******warning****
configuration Replication is NOT performed From standby Unit to Active Unit
configurations are no longer synchronized.
Hope you guys pull me out from these issues
Thanks & Regards
srikanth
cadet alain
If you could leave one only one thread for your problem and in the Firewall section of security you already did,it would be simpler for everybody to help.
Alain.
