stuck in rommon
I did an erase on a 3640.
it boots to rommon
while booting or tryin to dir flash: i get "device does not contain a valid magic number"
so I do a confreg to boot to the boot helper but it just goes back to ROMMON.
So i can nor format the Flash: to load the new image!
I am doing this remotely,
anything I can do with being there?
1 REPLY
Re: stuck in rommon
check this URl which has solution to your problem.
http://www.ciscotaccc.com/kaidara-advisor/core/showcase?case=K19767059
you need to download the Cisco IOS image to the Flash through XMODEM as it looks like that current IOS loaded on your router is corrupted.
follow this URL to load a new IOS on your router.
http://www.cisco.com/en/US/customer/products/ps6441/products_command_reference_chapter09186a00804a8d23.html#wp1033538
HTH, rate if it does....
119
