04-16-2007 11:20 AM - edited 03-05-2019 03:29 PM
So lets say someone fatfingered the filename of a bin file on a switch. The filename instead of being just filename.bin is instead \192.168.1.1filename.bin
How in the world do you delete that? Is there an escape character you need to use or something?
04-16-2007 11:42 AM
Try the following, (assuming it is in the bootflash directory)..
Delete bootflash:192.168.1.1filename.bin
04-23-2007 10:26 AM
If you have CatOS you will need to issue the squeeze command also.
04-23-2007 10:32 AM
You can either delete the flash file or rename it
delete flash:
rename flash:
HTH, rate if it does
Narayan
