Webcast-Catalyst9k
Stupid Question Time
This line below means "deny ip any any"....correct?
deny ip 0.0.0.0 0.255.255.255 any
0.0.0.0 255.255.255.255 means "any", yes?
If so, this line, as part of an ACL, can indeed block an eBGP connection from forming were it to be applied on one of the peer interfaces. Correct?
I know that BGP is TCP, but the keyworkd "IP" in the ACL is all encompassing, right?
Thanks!
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Stupid Question Time
Joe
"0.0.0.0 255.255.255.255 means "any", yes ?"
Correct.
"If so, this line, as part of an ACL, can indeed block an eBGP connection from forming were it to be applied on one of the peer interfaces. Correct?"
Yes, if the acl was applied inbound on the interface and there was no entry before this line allowing BGP connectivity.
The keyword "ip" does indeed include TCP.
Jon
Joe
Correct.
Jon
Jon, thanks fo rth e answer.
I made a mistake, though.
The ACL's line 150 is not 0.0.0.0 255.255.255.255
it's deny ip 0.0.0.0 0.255.255.255
What exactly does this line do? It seems that its saying that all traffic coming from a source ip address of 0.X.X.X should be blocked? What kind of source address will have a 0 in the first octet?
"It seems that its saying that all traffic coming from a source ip address of 0.X.X.X should be blocked? What kind of source address will have a 0 in the first octet?"
Yes, it's to block anything sourced with a 0.x.x.x address. I would suspect a typo. =)
It could have been blackholing techniques also, but you'd see 192.168.0.0, 10.0.0.0, and 172.16.0.0 addresses in your acl as well.
HTH,
John
HTH, John *** Please rate all useful posts ***
107
