Subinterfaces on Routed Ports
If a port on a 3750 or 6509 switch is configured as a routed port, is it possible to configure subinterfaces on this port?
Silver
Re: Subinterfaces on Routed Ports
Hi Mike,
Subinterface command is not supported on 3750.The command seems to be a carryover from mainline IOS and does not seem to apply to this hardware.
Please see the following link
http://www.ciscotaccc.com/kaidara-advisor/lanswitching/showcase?case=K305234
95
Routed Ports
A routed port is a physical port that acts like a port on a router; it does not have to be connected to a router. A routed port is not associated with a particular VLAN, as is an access port. A routed port behaves like a regular router interface, except that it does
not support VLAN subinterfaces. Routed ports can be configured with a Layer 3 routing
protocol. A routed port is a Layer 3 interface only and does not support Layer 2
protocols, such as DTP and STP.
Hope it helps you.
satish
Thanks, Satish.
Is it possible to have subinterfaces on a routed port on the 6509?
Silver
Hi Mike,
As per the link mentioned below, software versions 12.1E do not support configuration of
subinterfaces or use of encapsulation keyword on LAN ports.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/l
3_int.htm#wp1027016
However, subinterface configuration is available for software versions 12.2SX.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/layer
3.htm
Please rate this if it is really helped you.
satish
I am new to posting on these forums. I have rated your response as very helpful. How do I indicate that your feedback has answered my question -- i.e. how do I add the red checkmark?
Thanks.
342
