subinterfaces - should i be able to ping them?
silly question, should i be able to ping a subinterface?
i have the following config:
1841#sh run
Building configuration...
Current configuration : 1287 bytes
version 12.4
hostname 1841
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
--More--
no ip dhcp use vrf connected
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.1.21.1 255.255.255.224
no snmp trap link-status
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 10.1.21.33 255.255.255.224
--More--
interface FastEthernet0/0.4
encapsulation dot1Q 4
ip address 10.1.21.65 255.255.255.224
interface FastEthernet0/0.5
encapsulation dot1Q 5
ip address 10.1.21.129 255.255.255.224
interface FastEthernet0/0.6
encapsulation dot1Q 6
ip address 10.1.21.193 255.255.255.224
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
--More--
no ip address
shutdown
clockrate 2000000
ip classless
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
i have a laptop plugged into the same switch as the router, with ip address of:
10.1.21.2 255.255.255.224
gateway 10.1.21.1
and i cant ping the subinterface 10.1.21.1
even from the router i cant ping the laptop 10.1.21.2...
this seems to simple its embarrassing... can anyone help?
Re: subinterfaces - should i be able to ping them?
based on the configuration that you write down, your laptop was inserted in vlan 2, so check the port that you insert the laptop if it is in the same vlan or the default.
the next things, most operating system with firewall feature deny icmp to pass the devices so may be your configuration is right, so try ping from switch to router or from subinterface to the other sub interface.
yes the router and the laptop are in the same VLAN which is vlan2.
its a windows xp laptop with the firewall disabled.
i can ping all subinterfaces from the router,
i should elaborate... im trying to setup some VLANs in a test lab, i cannot get devices on different VLANs to communicate, devices in the same vlan communicate fine but not different VLANs.
This obviously is a router problem since communication between vlans requires a layer 3 device... but as far as i can see my config on the router is good.
even if you disable firewall you must spesifically permt icmp echo from windows
by the way your switch muxt 2950 or up at least since 1900 series just support isl and not dot1q.
for finishing the test create
interface vlan 2
ip address
and try to ping it from the switch and if it is okay so there is no error and just matter of icmp port issue.
otherwise we will think about it
rate if it is helpfull
im pretty sure this is not the problem as ping traffic works fine for devices in the same vlan.
if I get rid of my subinterfaces and set an ip address on the physical interface i can ping it without an issue.
note im using a dell 2724 switch (dont yell! haha)
Silver
Is the switch port the router is connected to setup for trunking with do1q encap? Is your client in the correct VLan?
Chad
HI
Can u verify the port on ur switch is trunking and all the vlans are allowed on it.
Mahmood
818
