Community Member
subneting
Hi ,
may someone correct me pertaining the subneting concept.
Question 1
172.17.16.1
255.255.254.0
from above, means my ip address will start from 172.17.16.x till 172.17.17.x
or
start from 172.17.15.x till 172.17.16.x
regards,
Jackal
2 ACCEPTED SOLUTIONS
Re: subneting
Hi Jackal,
Your first option is correct.
Ip address will start from 172.17.16.x till 172.17.17.x
Ankur
Re: subneting
Hi Jackal,
It all depends on the subnet mask which you have. In your case you mask was 255.255.254.0 so it can start like 172.17.20.x and will go till 172.17.21.x and next can be 172.17.22.x till 172.17.23.x and so on.
But if I take the same example with mask as 255.255.248.0 then it will not start from 172.17.20.x then it will start from 172.17.16.x and will go till 172.17.23.x
Ankur
*Pls rate all helpfull post
Re: subneting
Hi Jackal,
Ankur
Community Member
Re: subneting
Hi Ankur,
thanks for reply, so which means it always follow by the first ip range such as 172.17.16.x then 172.17.17.x .
even i start from any number like 172.17.20.x then the coming up will be 172.17.21.x , right ? correct me if i am wrong.
regards,
Jackal
Re: subneting
Hi Jackal,
Ankur
Re: subneting
Hi Jackal,
go thru this online subnet calculator,which makes you clear.
http://www.subnet-calculator.com/
hope this helps.
rate this post if satisfied.
136
