subscriber policy
What does this mean?
"subscriber policy recording rules limit 64"
I can only find the "subscriber-policy" keyword, but not subscriber. Where can I find the command guide?
Thanks and Regards,
Sarah
Bronze
Re: subscriber policy
This command is enabled by default. It sets the number of rules that are displayed in the show subscriber session detail command.
Hi Beth,
Thanks a lot!
Is there a website which explains all the default configuration in Cisco?
Sarah
Hi Sarah
AFAIK if you know the command you can very well check with the respective ios codes to find the explanation for the same.
you can refer this link which can be helpful..
http://www.cisco.com/en/US/products/ps6441/prod_command_reference_list.html
regds
308
