Community Member
Successor and Feasible Successor
In EIGRP, if Successor route fails and there is no feasible successor route available, how EIGRP will react?
1 ACCEPTED SOLUTION
Re: Successor and Feasible Successor
There are sometimes the situation happens that you have described above. If that happens the EIGRP declares the route as SIA " Stuck in Active " routes. When you do " show eigrp active " its lists the router address from which the reply is pending and then you can troubleshoot the issue.There could be some problem with the router, may be some bandwidth issue, some link issue due to which a reply is pending.
Please see the link below for more information:
http://www.cisco.com/warp/public/103/18.html
HTH,
-amit singh
Community Member
The short answer is that (DUAL) recomputation occurs when no feasible successor route exists.
Details:
If a route becomes unreachable e.g. the link to the Successor fails, then the router looks in its Topology Table
for another route with a lower metric than its Feasible Distance i.e. a Feasible Successor, and that one becomes the Successor.
This requires no neighbour querying and is therefore very fast.
If no feasible successor exists,
- queries are sent out to the network
- Diffusing computation is performed to select another feasible route
Community Member
Your answer assured me about what I was thinking. Thanks alot.
My only doubt is, the time waiting to send the queries and find a new successor route, what will happen to packets destined to failed route?
Thanks again.
HTH,
-amit singh
Community Member
Hi persepolis77,
If there is no route for the packets, they will be dropped, creating a black hole.
HTH, please rate all posts
320
