Webcast-Catalyst9k
Suggestion Required
Dear All
I have attached network diagram and task list  kindly check and suggest what best could be done to solve this problem.  Make sure Core Switch is layer 3 Switch not Router and Layer 2 switches are manageable switches. If there is any confusion feel free to ask me.
Task 1:-
PC1 can ping PC2
Task 2:-
PC1 can Ping PC4
Task 3:-
PC1 can Ping PC5 and PC6
Task 4:-
PC1 can ping Server 1,2 and 3
Task 5:-
PC6 can ping Server 1,2 and 3
Silver
Suggestion Required
What problem do you have, I don't see your question anywhere.
Siddhartha
Hall of Fame Super Gold
Re: Suggestion Required
I think the thread owner would like someone to make his school assignment.
There are task listed that need to be completed. I haven't gone through configuration when I post this threat. All I need is suggestions that this scenario is possible or not, I have no idea what you do in school because when I am in school apple and Black berry are just fruits
Every task that is listed can be made if you configure the core-switch properly.
Let us know where you are struck so that we could help you out.
-Vijay
This is easy, just stick all in the same VLAN and put an SVI on your L2 switch, this way everything can ping anything!!
NEXT
Please remember to rate useful posts, by clicking on the stars below.
thank you all for the suggestion Finally I am able to complete my school assignment . well I think I am not able to elobrate my problem very well. Basically one of customercomplain about slow network and ping drops. I investigate and check that everything is default in their Network not even host name is configured. having 40 switches and 20 servers you can imagine whats going on in the network so this is the solution I suggested (Check Network diagram for details). Now I have configured proposed solution on Packet tracer and everything worked perfect. Thanks alot for your inputs and appologies for any inconvenience
323
