SUP 1 to SUP 2E - EPLD upgrades ?
Hi All
We have a pair of N7K's with SUP 1. Earlier this SUP 1 was running 5.1(5), and we have done an upgrade for this SUP1 to 6.2(8a) with an intermediate version 5.2(7).
Everything worked good with ISSU. As of now, we have the N7K's with SUP 1 and with 6.2(8a) image.
We are going to upgrade this SUP 1 with SUP 2E (also with 6.2(8a)). We have M132's, M108 modules in the chassis. Do we need to do any EPLD upgrades in this scenario ? I know that this process is disruptive, but how will we know if we need to do EPLD or not ? or will it automatically do it ?
Thanks in Advance.
Raj
  • LAN Switching and Routing
Everyone's tags (1)
1 ACCEPTED SOLUTION
Reza,I recently encountered
Reza,
I recently encountered for one of my customer that EPLD upgrade in the latest ios was not automatically upgraded and we had to do it manully.
Reason:
DOM features were not supported.
Issue which I saw was that after upgrade :-
sh interface transceiver detail - no values
Solution: To support the DOM, it requires the latest version of IOFPGA or EPLD.    NXOS will read the IOFPGA version to determine whether it is going to request the IOFPGA to perform the DOM read.
VIP Super Bronze
Hi,Usually you don't need to
Usually you don't need to upgrade the ELPD individually since it is done automatically when you upgrade the code. But to be sure talk to your SE or TAC.
Reza,
Reason:
Thanks Reza and Insharie ill
ill be doing the supervisor upgrade today. SUP 1 will be replaced with SUP 2E. Ill check the show interface transceiver to check if everything is good. If not, ill do the EPLD upgrades manually to check.
Thanks again :)
Raj
Hi Reza/Insharie I did these
Hi Reza/Insharie
I did these upgrades yesterday. The switch didnt automatically do EPLD upgrade, probably because "no system auto-upgrade epld" is enabled by default.
The M1 modules were already upto their latest version of EPLD 2.007, but there were a few things which had to be upgraded , like:
LC FE Bridge 186.006 -> upgraded to 186.008
SUP Power Manager SPI 36.000 -> upgraded to 37.000
Apart from this, everything was already the right version of EPLD.
We did not see the DOM issue . SFP which were DOM capable showed transceiver values, and SFP which didnt support DOM - gave an error saying DOM isnt supported.
Thanks for all your help
Raj
Great Job Raj.RegardsInayath
Great Job Raj.
Inayath
62
