03-19-2010 06:26 AM - edited 03-06-2019 10:13 AM
I have a 6509 with redundant SUP720s in it. My question is how does the 6509 determine which SUP to boot to? Current it boots to the SUP in slot 6 and I'd rather it boot to the SUP in slot 5. Is the boot order determined by lowest MAC address of something on the SUP or is their a config setting I can change?
Jeff
03-19-2010 06:46 AM
Hi Jeff,
When power is first applied to a switch, the supervisor engine that boots first becomes the active supervisor engine and remains active until a switchover occurs.
A switchover will occur when one or more of the following events take place
The active supervisor engine fails (due to either hardware or software function) or is removed.
A user forces a switchover.
A user reloads the active supervisor engine.
03-19-2010 07:03 AM
Hello Jeff,
both supervisors load the IOS image and they start to talk on the backplane
probably the faster one wins and is elected the active supervisor
Hope to help
Giuseppe
03-19-2010 07:31 AM
Jeff
Jeff,
Once both sups are booted and every thing is working correctly you can change slot 5 to be the primary by using the redundancy force-switchover
Be aware that now the new stand-by sup will reboot
From the config guide:
Conducts a manual switchover to the redundant supervisor engine. The redundant supervisor engine becomes the new active supervisor engine running the new Cisco IOS image. The modules are reloaded and the module software is downloaded from the new active supervisor engine.
The old active supervisor engine reboots with the new image and becomes the redundant supervisor engine.
Reza
