06-30-2010 11:29 PM - edited 03-06-2019 11:51 AM
I have a 6506-E switch and trying to insert ws-x6k-sup2-2ge in slot. Tried in first slot and 5th and 6th slot. In all the slots the sup engine comes up. Need to know which is the recommented slot in 6506-E switch to insert the above sup engine.
Also if i am inserting sup 32 in the same switch, which is the recommented slot...
Solved! Go to Solution.
07-01-2010 04:32 AM
Richard
sup2 goes into slots 1 & 2 (2 is used for standby sup)
sup32 goes into slots 5 & 6 (6 is used for standby)
Jon
06-30-2010 11:56 PM
As per the link Sup engine slot for 6506E switches is slot number 1,just check out the below link for more information
http://csrc.nist.gov/groups/STM/cmvp/documents/140-1/140sp/140sp1155.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-01-2010 04:32 AM
Richard
Jon
07-01-2010 04:35 AM
Thanks a lot for the inputs....
