Community Member
Sup2/MSFC2 memory question
If I purchase the Sup2/MSFC2 at this time, am I right that it would ship with a default of 256meg of memory on the Supervisor and 256meg of memory on the MSFC ?
I am being quoted $2,196 to upgrade to 512meg for the Supervisor - MEM-S2-512MB= and $2,196 to upgrade the MSFC MEM-MSFC2-512MB=
Can I purchase the Sup2/MSFC and upgrade to 512 later if needed ?
How can I do analysis to judge if I would need the additional memory ?
Darren
1 REPLY
Re: Sup2/MSFC2 memory question
Hi Darren,
The Catalyst 6500 series Supervisor Engine 2 ships with 256-MB DRAM (WS-X6K-S2U-MSFC2) and the default 128-MB DRAM (WS-X6K-S2-MSFC2), both of which fully support software release 8.x.
When running software release 8.x with a large number of routes configured, the Supervisor Engine 2 requires 256-MB DRAM. The exact number of routes supported by the Supervisor Engine 2 with 128-MB DRAM depends on the features you have configured.
The Catalyst 6500 series Supervisor Engine 2 ships with a 32-MB bootflash device.
Check the release notes for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_4498.htm#wp550839
Ankur
222
