02-22-2007 05:47 AM - edited 03-05-2019 02:30 PM
Our 7603 has a PCMCIA 24MB Flash card in it from which the IOS is loaded (slot0:). Is it possible to remove this card while the router is up and running? Is there a procedure to effectively "dismount" the device prior to removing it, if so? Thank you,
Bob
Solved! Go to Solution.
02-22-2007 07:04 AM
You can just take it out no special procedures , you will see it in the logs but it doesn't affect anything .
02-22-2007 07:04 AM
