SUP2T no power
I have a 6506E chassis that I am upgrading to a pair of SUP2Ts.  When I shutdown the chassis and install the SUP2T they never power up.  I dont get any status lights or anything.
On the 1st chassis I upgraded we had no problems and so I "borrowed" a known working SUP2T and tried it in that 2nd chassis with the same result (no power to the SUP2T).
I put the SUP720-3Bs back into the chassis and they boot up without a hitch.  There is no messages from the SUP2T console connection or anything.
Any ideas?
Thanks.
Hall of Fame Super Gold
SUP2T no power
Could be DOA.  You may need to RMA it if the supervisor card doesn't power up (but the fan does).
SUP2T no power
Except I put a "known working" SUP2T in and it fails to power up too.  So its not likely the SUP module and why would the SUP720-3B power up without any problems?
Hall of Fame Super Blue
SUP2T no power
What power supply do you have in the chassis ie.
sup720 needs 2500W minimum
sup2T needs 3000W minimum
Jon
Re: SUP2T no power
I have a pair of 2500W in both Chassis.  The two 2500W power all my current modules except one and the SUP2T from the 1st chassis without an issue.  I have four 6000W power supplies on the way already so if that fixes it then great.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/white_paper_c11-676346.html
show power
system power redundancy mode = redundant
system power total =     2331.00 Watts (55.50 Amps @ 42V)
system power used =      1931.58 Watts (45.99 Amps @ 42V)
system power available =  399.42 Watts ( 9.51 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       2331.00 55.50  OK     OK     on
2    WS-CAC-2500W       2331.00 55.50  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN      140.70  3.35  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6748-GE-TX      404.88  9.64   404.88  9.64  on    on
2    WS-X6816-10T        514.92 12.26   514.92 12.26  on    on
4    WS-X6908-10G        588.00 14.00     -     -     on    off (FRU-power denied)
5    VS-SUP2T-10G        435.54 10.37   435.54 10.37  on    on
6    VS-SUP2T-10G        435.54 10.37   435.54 10.37  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   7266.00 Watts (173.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              1931.58 Watts (45.99 Amps @ 42V)
system auxiliary power used =            0 Watt
SUP2T no power
Sorry, my mistake. I was looking at current specs sheet and it say a minimum of 3000W because the 2500W is no longer for sale
Only thing i can think of is the connectors in the physical chassis as in the sup2T is having a problem being seated properly but that is really just a guess.
Jon
Purple
SUP2T no power
  Try putting the power mode as combined and see if it will power up, if so then you know the power supplies are inadequate.
Re: SUP2T no power
There is no way of doing that.  I have no console or anything.
Well we tried to install the
Well we tried to install the SUP2T again yesterday and they worked.  Exact same procedure as before but this time they decided to power up.
Very odd.
203
