SUP2T QOS channel consistency
cminard
Hi all
I have a catalyst 6506E (WS-C6506-E) with a SUP2T supervisor (VS-S2T-10G) card and a 10G interface card (WS-X6816-10G-2T) + DFC4.
I have configured an etherchannel to another switch with the 2 10Giga ports of the SUP2T card and 2 10giga ports of the interface card.
I only use the 10Giga ports of the SUP2T card so the cards have the same QOS transmit capabilities.
But they do not have the same receive capabilities.
So when I configure QOS (with the new commands on SUP2T) on my 4 ports within the Etherchannel, 2 ports move down because of the inconsistency.
Till this point, no surprise.
The problem is that the command "no platform qos channel consistency" replacing the "no mls qos channel-consistency" does not exist.
I run the last IOS 12.2(50)SY1 IPSERVICESK9.
And I cannot have QOS on my Etherchannel on the 2 cards.
Or I have to use 4 ports of my interface card but in case of failure of this card, I loose the whole etherchannel.
I there a way to avoid the consistency check ?
Is there another command to use ?
Help please.
Caroline
Ivan Shirshin
Hi Caroline,
It seems that you have a mistype with that command, as it should be "no platform qos channel-consistency". Could you try it this way (configured on port-channel)?
Kind Regards,
Ivan
Kind Regards,
Ivan
Ivan Shirshin
Hi Caroline,
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
You're right.
I tried the command (with or without the -) in global config only, and not on port-channel ...
It was just that.
Caroline
