Community Member
Sup720-10G ASICs
Interested to know what the command is that will show the ASIC
to port mapping on the 6500? I want to assess the impact of QoS changes on some ports, and how those changes
will get propagated to other ports on the same ASIC.
Hall of Fame Super Blue
Re: Sup720-10G ASICs
Don't know the command but you can use the release notes for this, just go to the module you are interested in and it lists the port groups/port ranges -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/release/notes/OL_4164.html
Jon
Hall of Fame Super Bronze
Router> show interfaces capabilities module 6
FastEthernet6/1
Dot1x: yes
Model: WS-X6248-RJ-45
Type: 10/100BaseTX
Speed: 10,100,auto
Duplex: half,full
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on),tx-(none)
Membership: static
Fast Start: yes
QOS scheduling: rx-(1q4t), tx-(2q2t)
CoS rewrite: yes
ToS rewrite: yes
Inline power: no
SPAN: source/destination
UDLD yes
Link Debounce: yes
Link Debounce Time: no
Ports on ASIC: 1-12
Port-Security: yes
1013
