09-18-2008 06:20 AM - edited 03-06-2019 01:27 AM
I've taken a standby supervisor out of a 6509 chassis and installed it in a 6504-E chassis.
Couple of problems I observed.
1.switch boots up into rommon mode
2.show mod output shows the sup720 installed into slot 5 of a 6504-E which we all know is impossible as there are only 4 slots.
Some outputs are in the attached file from rommon and from after the switch is started.
any help would be appreciated!
09-18-2008 07:04 AM
Is it going booting manually
If you can run "show module" that means you are able boot the switch.?
use command
"remote command switch show version"
see the value of config-register
if it is not 0x2102, then correct it into rommon & then boot it
HTH...rate if helpful..
09-18-2008 09:34 PM
once in rommon mode I have to issue a boot command then the switch boots up. command "remote command switch show vers" says "cant connect to remote switch"
any other ideas?
09-18-2008 11:25 PM
OK,
First restore the switch to factory default settings.
Use write erase command "write erase" & reload
then see the results.
Again use "remote command switch show version" in enable privilege mode.
HTH..rate if helpful..
09-18-2008 11:37 PM
Ok, forgot to mention I have already restored this to factory default settings and here is the output that I saved.
It starts up and says the sup720 is in slot 5 I can't remote command to switch either. I've eventried another chassis(6504-e) same problem
What could be the problem here?
#### after write erase and erase const_nvram:
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
Initializing ATA monitor library...
string is bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF7.bin
Loading image, please wait ...
00:00:51: curr is 0x0
00:00:51: RP: Currently running ROMMON from S (Gold) region
00:01:17: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/network-confg) failed
00:01:17: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cisconet.cfg) failed
00:01:26: %SYS-5-RESTART: System restarted --
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Router>
Router>
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 06:42 by kellythw
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:04: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
00:00:05: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 25-Oct-06 15:36 by integ Build [100]
00:00:59: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:59: SP: SP: Currently running ROMMON from S (Gold) region
00:01:25: %SYS-SP-5-RESTART: System restarted --
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Compiled Thu 23-Nov-06 06:48 by kellythw
00:01:27: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:27: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:01:28: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:28: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:28: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
11-11-2008 08:13 AM
hello! I'm having the same problem.
whe I reload the 6509 switch, I get into rommon and it will only boot using the boot command.
11-11-2008 09:09 AM
When you are in Rommon mode can you enter
rommon 1 > confreg 0x2102
Jon
