01-10-2009 09:13 AM - edited 03-06-2019 03:21 AM
At my company, we introduced iSCSI to our network, and find it at issue when our switch reboots, it takes to long... I did some research on SSO, It seems to me to be a much better way to go.. rather than RPR mode.. Can you view my current supervisor config and give input?.. thank you
Solved! Go to Solution.
01-11-2009 11:03 AM
ok, i followed the instructions you posted changing the bootstring.. it worked beautifully... thank you for your mentoring...
rob davis
01-11-2009 11:30 AM
No problem! Glad I was able to help
Best of luck,
Mark
01-11-2009 11:02 AM
You can use the existing IOS already in flash.
01-11-2009 11:04 AM
I would just go ahead and reload the standby supervisor then. If it already has the file in flash you should be good to go.
01-10-2009 10:35 AM
one more thing. about switching to SSO from RPR on the Supv. would this be worth doing?, does it not really matter.....
thanks for all your help...
rob davis
01-10-2009 10:47 AM
In my opinion it is worth doing. The supervisor failover times are are greatly reduced using SSO (SSO=50 Milliseconds Vs 45-120 seconds with RPR).
Once it is configured you are good to go, and it's relatively easy to configure.
HTH,
Mark
01-10-2009 12:53 PM
You will have much faster failover with SSO , thats the way to go.
