Supervisor engine 720 redundancy takeover failure
Here is the configuration,
1x 6513
1x WS-C6K-13slot
2x ws-sup720-3b
2x ws-cdc-2500W
2x ws-x6516a-gbic
2x ws-x6548-rj-45
OS image :
The sups are in redundancy mode. They are both running the following image:
S72033-pk9sv-mz.122-17d.sxb11.bin
Issue :
The redundant sup did not pick up properly
Indicates that the" boot file did not load, it stayed in ROM monitor"
1)Why did the supervisor engine fail?
2) why didn't the redundant supervisor engine pickup when the active one failed?
Please help me out to fix this issue. Its critical. Thanks in advance
Re: Supervisor engine 720 redundancy takeover failure
There are many possible reasons why this is happening. I would like to see what your config-register values are. Can you please post the output of "show version" and "show redundancy".
Mark
Redundant System Information :
Available system uptime = 2 days, 23 hours, 16 minutes
Switchovers system experienced = 0
Standby failures = 3
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = sso
Operating Redundancy Mode = sso
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 8
Current Software state = ACTIVE
Uptime in current state = 2 days, 23 hours, 16 minutes
Image Version = Cisco Internetwork Operating System Software
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 14-Sep-07 22:01 by kellythw
BOOT = sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin,12;
BOOTLDR =
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 7
Current Software state = STANDBY HOT
Uptime in current state = 2 days, 23 hours, 1 minute
BOOTLDR =
Show version
Image text-base: 0x40101040, data-base: 0x42DBD2B0
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF11, RELEASE SOFTWARE (fc1)
1118th307-6513-01 uptime is 2 days, 23 hours, 20 minutes
Time since 1118th307-6513-01 switched to active is 2 days, 23 hours, 19 minutes
System returned to ROM by s/w reset (SP by error - a Software forced crash, PC 0x402DF044)
System image file is "sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513 (R7000) processor (revision 1.0) with 458720K/65536K bytes of memory.
Processor board ID TBM06150127
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
144 FastEthernet/IEEE 802.3 interfaces
36 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Hi mark,
Please find herewith the results of show version and show redundancy results,
Please help me out on this. The config reg values are 0x2102
Log file
log file
The supervisor engine 720(slot 7) was failed on Sunday and unable to take over the slot 8 (redundant) supervisor engine. After the reboot, the slot 8 was active but the slot 7 was keeps rebooting and stayed in ROMMON mode.
Need to find out the following info,
1. Why the failure happen? attached log file.
2. why the takeover of redundant supervisor 720 failed?
3. why the failed sup keeps on rommon mode and keeps rebooting?
Thanks in advance.
regards,
Siva
Siva,
Thanks for the posted info. Not too sure why it keeps booting into rommon. Before we jump to conclusions about faulty hardware, can you post the crashinfo file on your bootflash? I saw where the was a Software forced crash in the show version output. This crash file should give us an answer as to what the real problem is.
Mark
-#- ED ----type---- --crc--- -seek-- nlen -length- ---------date/time--------- name
1 .. crashinfo 5CD968E5 C90E8 25 299112 Mar 1 2009 06:06:26 -05:00 crashinfo_20090301-110626
65236760 bytes available (299240 bytes used)
Hi mark,
I posted here the output of bootflash:
Then second thing, i wish to know about switchover between supervisor engine, can you please help me out?
Directory of bootflash:/
1 -rw- 299112 Mar 1 2009 06:06:26 -05:00 crashinfo_20090301-110626
65536000 bytes total (65236760 bytes free)
Can you actually pull the crashfile from the switch and post it on here? I am trying to investigate as to why the redundancy is not working.
Okay, i will do that, before that can you please guide to do switchover from Active Sup720 to Standby Sup720.
Thanks again
The command to force a failover is "redundancy force-switchover". You shouldn't need to failover the supervisors to get the crashfile (unless you are doing something else).
Thanks again.
I am trying to check if that happens again.
How can i get the crashfile to you?
Can you please tel me, how i can get the crushfile from the sup720
Mark,
How i can get you the crashfile, is that by trasfer upload /path?
If you have a PC running a TFTP server ( I personally use and recommend tftpd32). You will want to copy the crashfile using tftp.
copy bootflash:crashfilename tftp
Address or name of remote host []? 10.10.1.100 (replace IP with your PC IP address)
Destination filename [crashfilename]?
10035 bytes copied in 0.068 secs (147574 bytes/sec)
Note: Make sure the crashfile name is correct. Verify this by issuing the show bootflash: command.
Then add the crashfile as an attachment on the forum.
HTH,
Mark
Thanks Mark, i will get the crashfile today
I am working on the ssh, and the tftp server not configured at the remote end.
how i can get you the details ?
copy crashinfo_20090301-110626 tftpd32
The above command copied the information, how i can get the file?
Hi mark,
Thank you for your continues support. i appreciate Mark!
I am sorry for the last post, as i was new to tftpd32.
Okay , i got the crashfile and attaching herewith, please provide me the cause of the redundancy failure.
Thanks in advance.
931
