Webcast-Catalyst9k
Support for TDR cable diagnostics
Dear friends,
The command test diagnostics cable-tdr interface <> does not seem to be supported on the new 4500 E-Series line card viz. WS-X4648-RJ45V-E. It says that the command is not supported on this module.
Is there any alternative to this issue that you could suggest
We are running 4500E with Sup 6-E and IOS ver 12.2(50)SG.
Thanks a lot
Gautam
Hall of Fame Super Gold
Re: Support for TDR cable diagnostics
Thanks. But i already tried this command and it shows that it is not supported on this module.
The exact output that i received was :
%C4K_IOSDIAGMAN-4-TESTNOTSUPPORTEDONMODULE: Online cabl
e diag tdr test is not supported on module 1
The module that i am trying for is:
WS-X4648-RJ45V-E
Thanks a lot
Gautam
Hold on ... what is the syntax of your command?
"test diagnostics cable-tdr interface" for the 4500 is not valid. It's now "test cable-diagnostics tdr".
Sorry, i meant that i used the command test cable-diagnostics tdr only. But it did not work.
Thanks a lot
Gautam
1092
