%SVCLC-5-FWTRUNK but I don't have FWSM on my 6513 box ?
I have the following log on my Cisco 6513 chassis:
%SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
I have already seen the explantaion in the post below:
https://supportforums.cisco.com/docs/DOC-4831
I don't understand what does it mean because I don't have a Firewall module running on this device ?
If anybody can help ...
Ju
  • LAN Switching and Routing
Everyone's tags (1)
Hall of Fame Super Blue
Re: %SVCLC-5-FWTRUNK but I don't have FWSM on my 6513 box ?
Can you post -
1) "sh run" from the switch
2) "sh module" from the switch
Jon
Hi Jon,
You will attached the requested output.
Thank you ,
ju
Ju
Do you have any othe 6500 switches trunked to this with the FWSM in it ?
Jon
No,
I have a 6513 trunked with this one, but there is no Firewall module in. The two chassis have exactly the same modules.
Ju
ju.mahieu wrote:
No,
Ju
Ju
And on that 6500 you have no firewall commands configured ?
If not only thing i can think of is it is getting mixed up with the ACE config lines but that does seem unlikely. I'll have a quick check in bug tool when i get a chance.
Jon
No, I don't have any fiewall commands configured on my two chassis ...
Very strange...
Thank you for your search
ju
Hey there,
would be cool to know if this problem has been solved. I´ve got the same issue here. Its a 6509 running without a FWSM but an ACE-Module. No Firewall commands configured either.
Does anyone has a solution to this?
Thanks in advance,
Patrick
714
