SVI not coming up in Cisco 5548
I have recently purchased Cisco 5548 with Layer 3 license but when configured multiple SVI's none of them coming up.
I have configured layer 2 vlans, enabled feature and did check module is up or not. In addition I checked License usage as well and all looks good but still SVI is not coming up.
Can anyone help me or faced the same issue in their environment.
Puneet
In order for an svi to come
In order for an svi to come up, you need to have a device in that vlan. Do you have anything connected to the switch?
HTH, John *** Please rate all useful posts ***
two Cisco 5k connected to
two Cisco 5k connected to each other and below that Cisco fex is connected.
there is no device connected yet.
In addition the moment I put
In addition the moment I put 'management' command under SVI it comes up.
In order for an SVI to come
In order for an SVI to come up you need a connected and active Layer 2 port on that switch which is either:
A) An access port, i.e a host is connected in that Vlan
B) A Trunk port - The trunk port must be up and be carrying that vlan.
If not, the SVI will not come up.
When you say 'two Cisco 5k connected to each other', are these connected at Layer 3 (i.e an ip address each end' or via a Layer 2 Trunk?
Did it drop any error
Did it drop any error messages or logs?
229
