SVI on Distribution Switch and root bridge on access layer
Me and colleague at work had a discussion about root bridge and SVI. According to him Root bridge of a vlan and its SVI should be on a distribution switch. If SVI is on distribution switch and root bridge defined on access switch, it will be a problem. Can anyone explain why would it be a problem? I will also appreciate if someone can explain the traffic flow in both cases.
Thank you for taking time to answer this question.
Everyone's tags (1)
1 REPLY
Hi , Can you share the
Hi ,
 Can you share the topology diagram ??
Sandy
75
