SW_MATM-4-MACFLAP_NOTIF
frede_frede
I have a big problem with Vlan flapping, this is my topology
Switch 1 and Switch 2 have the SVI and HSRP configured. Switch 1 is the root bridge for all Vlans. The message vlan X is flapping between port Gi1/0/2 and port Po2 appears on Switch 3. The Po2 is connected to Switch 1.
The port settings in Sw3:
spanning-tree mode pvst
spanning-tree vlan 1-4094 priority 12288
interface Port-channel1
description "Sw2"
switchport trunk allowed vlan 10,11,12,13
switchport mode trunk
switchport nonegotiate
spanning-tree vlan 1-4094 cost 6
interface Port-channel2
description "Sw1"
interface GigabitEthernet1/0/21
description "Sw2"
channel-group 1 mode passive
interface GigabitEthernet1/0/22
description "Sw2"
interface GigabitEthernet1/0/23
description "Sw1"
channel-group 2 mode passive
interface GigabitEthernet1/0/24
description "Sw1"
In switch 1 and 2 settings are the same except the mode of the channel-group which is active.
I think the problem with "vlan X is flapping" is on the doors of servers that have more than one nic connected to the switch, a misconfiguration can cause the message "Vlan X is flapping Between port Gi1/0/2and port Po2 " and others messages, I say this because this message only appears in configured ports of two VLANs and not in the other two.
Is there any way to prevent such events, even if the problem is the servers?
Thank you for your help
20 Replies 20
Hi Vivek,
Today the MAC flap error happened again:
2012-06-17 12:10:58 SW_MATM-4-MACFLAP_NOTIF Host 0030.13e5.34f1 in vlan 10 is flapping between port Gi1/0/20 and port Po2
2012-06-17 12:10:57 SW_MATM-4-MACFLAP_NOTIF Host 0015.1728.420a in vlan 11 is flapping between port Gi1/0/14 and port Po2
2012-06-17 12:10:57 SW_MATM-4-MACFLAP_NOTIF Host 0015.1728.420c in vlan 11 is flapping between port Gi1/0/13 and port Po2
2012-06-17 12:10:57 SW_MATM-4-MACFLAP_NOTIF Host 0030.13e5.34f2 in vlan 10 is flapping between port Gi1/0/17 and port Po2
2012-06-17 12:10:57 SW_MATM-4-MACFLAP_NOTIF Host 0030.13e5.34f3 in vlan 10 is flapping between port Gi1/0/19 and port Po2
2012-06-17 12:10:57 SW_MATM-4-MACFLAP_NOTIF Host 0030.13e5.34f0 in vlan 10 is flapping between port Gi1/0/18 and port Po2
2012-06-17 12:10:43 SW_MATM-4-MACFLAP_NOTIF Host 0030.13e5.34f0 in vlan 10 is flapping between port Gi1/0/18 and port Po2
and unfortunately there was no change in topology ...
VLAN0010 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 12288, sysid 10, address 0025.b4c0.c580
  Configured hello time 2, max age 20, forward delay 15
  Current root has priority 4163, address 0025.b4d8.6580
  Root port is 520 (Port-channel2), cost of root path is 3
  Topology change flag not set, detected flag not set
  Number of topology changes 4 last change occurred 1w2d ago
          from Port-channel2
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
the problem must be in the side of the servers, if I use LACP to the server will solve the problem
Fred
I think I saw the problem
the problem is in the SW1 Po3
  Bridge Identifier has priority 4096, sysid 10, address 0025.b4d8.6580
  We are the root of the spanning tree
  Number of topology changes 42 last change occurred 10:28:39 ago
          from Port-channel3
The SW2 has no changes.
I never had problems in the connecting to this switch blade, but I think the problem is in Pe5, the Po can stay in FWD and cause the loop. I unfortunately do not make management of blades, but I have to take a look.
Fred
Hi Fred,
Which VLAN do you use for data & management traffic? Looks to me like the impact is just to the management segment?
Vivek.
Hi Vivek,
I use the VLAN 100 for management, but this Vlan is not passing in Po3. The Vlans 10 and 11 with the mac flap problem, are the only ones in common between Po1 and Po3.
Fred
hey
i have and issue connecting two routers with a 2960 switch which is connected to the internet switch?
can you give me an EXAMPLE OF ANY CONFIGURATION TO CONNECT THE ROUTERS, THE ROUTERS ARE 3945 ROUTERS PLEASE
Help
Hi Vivek,
I Have managed to overcome the problem
I configured in Po4 a port-priority and I don't have any more problems
thanks for the help
Fred
