Swapping a Sup card for a 4507R
I currently have a 4507R with one Sup 2 card in it.
I bought a Sup 5 card with a Netflow daughter board to replace the Sup 2 card.
My question is can I install the Sup 5 card in the redundant slot ahead of time and then via IOS command flip from one card to the other reducing down time or do I need to down the 4507R switch altogether and then just swap out the cards.
The reason for trying to reduce the down time is that there are 3 regional call centers phone systems run through this switch and it is hard to schedule an outage.
1 ACCEPTED SOLUTION
Re: Swapping a Sup card for a 4507R
Hi Friend,
If you insert a sup 5 card into the chassis which is already running with sup 2 it will not come online and will stay in UNKNOWN/Other state the reason is 2 seperate kind of supervisors cannot exist working at a same time in a chassis.
So you have to bring down the switch completely to replace the card and make it working back again with sup 5.
Ankur
*Pls rate helpfull post
1 REPLY
Hi Friend,
Ankur
148
