Switch 2950 password
akramksajed
Dear All
I configured cisco S/W 2950-24ports and changed the default ip from 10.0.0.1 to 10.10.1.12, now i want to manage the switch from explore by pointing to this new IP. it prompt for level 15 user name and password. can any one let me know what is the default user name and passwor for the switch
appreciate your reply
farkascsgy
Level 4
Level 4
There is no default username and password for 2950 swithces.
You can reset the password based on the following procedure:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
bye
FCS
Please rate me if I helped.
FCS,
I believe the newer Cisco equipment comes preconfigured from factory with a local username/password combination of cisco/cisco. I don't know that's the case here. If it isn't then password recovery is the only option.
Sundar
Sundar,
You are totally right, but this is an 2950 switch.
Default passwords can be:
Cisco/Cisco
cisco/cisco
as Sundar wrote.
bye
FCS
glen.grant
there is no default username and password on a 2950 it would have been specifically configured on the 2950 by someone . Some devices like the 2800 series do come with a username and paswword on it , haven't figured out the point of that right out of the box and its cisco/cisco . You will probably have to do a password recovery if you can't figure it out.
