Community Member
Switch 3560 and Internet Adsl Telefonica Router
Hello:
I have a switch 3560 whit this configuration.
Port1 192.168.0.1 (no switchport)
Port2 192.168.2.1 (no switchport)
Port3 192.168.3.1 (no switchport)
On the port1 a "ADSL Telefonica router Zyxel 763" 192.168.0.99
On the port2 a PC 192.168.2.2
On the port3 a PC 192.168.3.2
Ping from PC to PC OK
Ping from PC to "ADSL Telefonica router Zyxel 763" KO
Ping from Switch console to "ADSL Telefonica router Zyxel 763" OK
Ping from "ADSL Telefonica router Zyxel 763" to Switch OK
My PCs can?t browse Internet.
Why i can?t ping the "ADSL Telefonica router Zyxel 763" from a PC?????
Lot of thanks
1 REPLY
Community Member
Re: Switch 3560 and Internet Adsl Telefonica Router
make sure ip routing is enabled on the switch
make sure there is a route on the switch, 0.0.0.0 0.0.0.0 192.168.0.99, and make sure you have used PAT on the router for those 3 networks
cheers
Carl
181
