Webcast-Catalyst9k
Switch 500 series - Smart ports
Hi all,
I am configuring a cisco switch 500 series and all access ports will be set as cisco-desktop smart port.
This switch will be connected to a 3com switch via uplink, vlan1. Which smart port should I use? Can I also use cisco-desktop?
Re: Switch 500 series - Smart ports
Hi Muca,
Desktop should work fine since we have all access ports.
~JG
Please rate helpful posts
Someone else told me:
You'll want to use the switch role on this port. Cisco-desktop role enables portfast and BPDUguard. If the 3com switch talks spanning-tree, this port will shut down upon connecting to the Cisco.
131
