11-23-2010 01:34 PM - edited 03-06-2019 02:11 PM
Hello:
Please I have two questions about the subject:
1.- First question, In a Stack of Switch Catalyst 3750, it can work with differents flavors, I mean, one switch that belong to the Stack have IOS version 12.2(35)SE5, IP BASE, another switch may have 12.2(35)SE5, IP Services, etc, the stack can work in this way...?????.
2.- Second Question, How I can, to Upgrade the IOS of a Switch Catalyst 3750, for example from IP BASE to IP SERVICES, I have the appropiate license, but when I try to do that, the following message apears:
Switch#$overwrite tftp://172.22.2.169/c3750-ipservices-tar.122-35.SE5.tar
Loading c3750-ipservices-tar.122-35.SE5.tar from 172.22.2.169 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 10741760 bytes]
examining image...
extracting info (108 bytes)
extracting c3750-ipservices-mz.122-35.SE5/info (616 bytes)
Stacking Version Number: 1.34
System Type: 0x00000000
Ios Image File Size: 0x007AFA00
Total Image File Size: 0x00A3C200
Minimum Dram required: 0x08000000
Image Suffix: ipservices-122-35.SE5
Image Directory: c3750-ipservices-mz.122-35.SE5
Image Name: c3750-ipservices-mz.122-35.SE5.bin
Image Feature: IP|LAYER_3|PLUS|MIN_DRAM_MEG=128
Error: The image in the archive which would be used to upgrade
Error: system number 1 does not support the same feature set.
Switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
Switch uptime is 6 minutes
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750-24P (PowerPC405) processor (revision P0) with 118784K/12280K bytes of memory.
Processor board ID FDO1406R11G
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : FC:FB:FB:2B:F0:00
Motherboard assembly number : 73-9672-13
Power supply part number : 341-0029-05
Motherboard serial number : FDO14060Q26
Power supply serial number : LIT14020Y46
Model revision number : P0
Motherboard revision number : A0
Model number : WS-C3750-24PS-S
System serial number : FDO1406R11G
Top Assembly Part Number : 800-25860-07
Top Assembly Revision Number : A0
Version ID : V08
CLEI Code Number : COMDL10BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24P 12.2(35)SE5 C3750-IPBASE-M
Expect your news.
Regards.
Fernando.
Switch con0 is now available
Press RETURN to get started.
Solved! Go to Solution.
11-23-2010 03:27 PM
Fernando,
Since you already have a license key, you just need to apply the license key to the switch and that will upgrade it from IP base to IP services. There is no need to download a new IOS to your switch The command is:
license install
see link below:
Also, make sure you use the same exact IOS for all your switches in the stack
Reza
11-23-2010 03:27 PM
Fernando,
license install
see link below:
Reza
11-23-2010 03:53 PM
Thanks very much for ypu Reza.
Regards.
11-24-2010 12:40 AM
Just for your information
If you want to upgrade from ip base to ip services you need to add this parameter:
/allow-feature-upgrade thus archive download-sw /allow-feature-upgrade tftp://x.x.x.x/image.tar
