Switch Comparison Sheet
Does anyone know where I can find a sheet comparing all the different switches Cisco carries?
Re: Switch Comparison Sheet
Hi Tabetha,
I have never seen such a sheet, if you browse to the Switching section within the Cisco website, you can find technical white paper's for all switches.
If you need some help with Switches, I can help out and provide my opinion on the best Switch to use.
Hi Tabetha,
Here is Cisco online tool for comparison as per your requirements.
http://www.ciscowebtools.com/productadvisor/switches.asp
Hope this helps... please rate if useful.
Dhananjoy
Have you tried Catalyst switch product guide. Have a quick look it may help!!
Cheers
1401
