Webcast-Catalyst9k
Switch Config Issue
Hi Team,
We are facing issue with one of our terminal server after recover password.
After login our TS it's showing like below, we can able to lgin and see the confif as well.
And one more issue with our Nexus switch console, all of out Nexus 5K as well getting continuos error like below
After Login TS:
login as: xxxx
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
Using keyboard-interactive authentication.
Password:
% Password expiration warning.
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
Replace <myuser> and <mypassword> with the username and password you want to
use.
Error Logs on Nexus 5K switches:
2013 Jul 11 20:10:38 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user                   ^ from c
onsole - login[23169]
2013 Jul 11 20:13:51 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ^g^g^g^g^g^g^g^g from cons
ole - login[23590]
2013 Jul 11 20:17:04 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user h^h^h^h^h^h^h^h^h^h^h^h^h^
h^h^h from console - login[23891]
2013 Jul 11 20:18:08 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user $ommand or computer name,
or un from console - login[23907]
2013 Jul 11 20:18:48 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user % Unknown command or compu
ter n from console - login[23933]
2013 Jul 11 20:19:53 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user                 ^ from con
sole - login[23950]
2013 Jul 11 20:20:57 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ^g^g^g^g^g^g^g^g from cons
ole - login[23963]
2013 Jul 11 20:21:09 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user e.
         ^H^H^H^H^H^H^H^H^H    * from console - login[23963]
2013 Jul 11 20:22:46 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user ^g^g^g^g^g^g^g^g^g^g^g^g^g
^g^g^ from console - login[24006]
2013 Jul 11 20:23:17 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user H^H^H^H^H^^G^G^G^G^G^ from
2013 Jul 11 20:25:17 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user nodmpxx-terms01>h^h^h^h^h^
h^h^h from console - login[24049]
2013 Jul 11 20:25:56 Nexus5K %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user                 ^ from con
sole - login[24066]
181
