Community Member
Switch configuration for ESX host NIC Teaming
There are many ESX hosts in our network environment. As default,we configure two NICs on ESX hosts as Teaming for Active/Active mode
. We also set up etherchannel on the switch end. They are working fine.
Like the following configurations:
interface Port-channel6
switchport trunk allowed vlan 10,86
switchport mode trunk
interface GigabitEthernet1/0/19
channel-group 6 mode on
interface GigabitEthernet2/0/19
But the right now they would like yo change NICs teaming as Active/Standby mode on ESX host.Could you please let me konw how to change switch end? Should we still use etherchannel for it? Thanks for your two cents!
Hall of Fame Super Blue
Re: Switch configuration for ESX host NIC Teaming
If the 2 NICs are connected to the same switch then you can't use etherchannel, you will have to configure them as separate L2 trunks. Ideally if you are using active/standby you want the NICs to be going to 2 separate switches which are interconnected via a L2 trunk.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Community Member
Thanks for your quick reponse. Right now the NICs in the Teaming are connected to different stack member switch. But it is logical one switch. So the A/A mode is working to us with etherchannel.
According to your suggestion, I rquire to remove the port-channel and keep the trunk settings if we still keep the current port connection, is it right?
Thanks again!
Thanks again!
Yes you need to break up the etherchannel but still configure both server links as L2 trunks.
Jon
Community Member
Thanks, I will let you know if it is working tomorrow.
1892
